jayme2468
Mar 28, 2022Follower
Internet LED not on
noo nnoo
Mar 28, 2022Guru - Experienced User
what router do you have?
What modem/gateway is it connected to?
You gave us nothing to go off.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
Love when my setup macros get copy/pasted by others.
