AliKDM
Dec 02, 2020Aspirant
Internet LED not turning solid green
I recently tried setting up my NETGEAR Nighthawk AC1900. The install guide that came with it says after connecting the wires. It might take 10 minutes for the Internet LED light to turn solid green. ...
Dec 02, 2020Guru - Experienced User
You have the C7100v?
Did you call your isp to have it activated?
or go through the activation wizard?
who's your isp?
- AliKDMDec 02, 2020Aspirant
No, I have the C7000. I tried to activate it with my ISP, but there saying the router modem needs to be turned on and running before they can activate it. The green Internet LED must be solid green before trying to activate it. I tried activating with Nighthawk app, even there saying the router modem appears offline.
- plemansDec 02, 2020Guru - Experienced User
A couple things.
1. the "internet" icon won't stay green until activated
2. Does the power led stay solid green?
3. do you have it connected to the coax entering the home? I know it sounds like a stupid question but I've regularly seen where people didn't have the coax connected properly or the coax runs through the home but is unhooked in a utility room
4. If the isp can't see it, it might not be connected.
5. if you connect a pc/laptop to it, (not app/wireless) are you able to log into the c7000?
Yes, the power LED stays solid green. Yes, the Coax cable is coming from the home. When I connect my laptop and iphone to the network I am able to log into the Netgear Genie. On their it says the Cabe Connection is still in progress. Looking deeply in their it also says, "Modem is offline, please check RF connection."
