roanaur
Nov 26, 2016Aspirant
Internet light is amber
As the title says, the internet icon is shining in amber, I have no internet. I've read that you're supposed to restart your modem and so on, but I don't have a modem. The cable runs directly from th...
- Nov 28, 2016
Hello roanaur
Welcome to the community!
Who is your ISP?
Try to do a power cycle by turning off everything then power on the router then the computer.
What kind of details have you configured in the router page?
You may also try to follow the provided steps below that is applicable to your connection.
How to configure your NETGEAR router for cable internet connection
roanaur
I have internet when i bypass the router and plug the internet cable directly into the computer.
