Aikarion
Feb 14, 2019Aspirant
Internet light is orange, but internet works fine?
Hey everyone,
I'm having a problem with my router that started happening after I moved to a new place. When plugged in, All lights turn Green except the Internet Light, Which remains orange. No...
- Feb 16, 2019
Maybe you just have to live with it. You seem to have tried everything.
Oh, dear just noticed this. According to Netgear's manual for this device the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware.It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX.
I'd lay money on your internet connection being faster than 100 Mbps.
This is a basic and inexpensive router. Time for a replacement.
michaelkenward
Feb 16, 2019Guru - Experienced User
That is a sign that it is not connecting to the internet.
There is a manual for the R6100 somewhere at the end of this link:
>>>> R6100 | Product | Support | NETGEAR <<<<
See Front panel LED descriptions.
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
- AikarionFeb 16, 2019Aspirant
Hey! Thanks for the reply. Unfortunately, There is no modem. The internet is Fiberoptic. Its a straight Cat6 from the wall to the outside box where its converted from fiber to cat6. I have no access to this box.
With that being said, I'm still able to pull and access internet through the router with no issues even though the light is orange.
- michaelkenwardFeb 16, 2019Guru - Experienced User
Yes, The internet is faster than 100Mbps. Or, It can be. So its orange because the internet is faster than the router can handle? I'm only paying for 100 up/down, and its "Restricted" to that speed on the ISP side. With that being said, If I wanted I could easily be paying for gigabit speeds. I just can't see why I'd ever need more than 100Mbps. I've yet to run into a bottleneck with videos, gaming, or any form of streaming.
