metanbeky
Apr 03, 2022Follower
Internet light orange on router?
Ok so like 2 days ago my wifi just stopped working, for no reason. I tried to reset it but it didn’t work. I thought the modem was the issue but it’s the router. And the internet light on the route...
Apr 04, 2022Guru - Experienced User
what device do you have?
What firmware is on it?
What modem/gateway is it connected to?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- wcalifasApr 05, 2022Prodigy
so when you say your wifi stopped working did it stop transmitting a signal or was it just that your internet wouldn't load up? Try doing a hard reset on your router by pressing the reset button with a paper clip. Let us know what happens to help you troubleshoot.
