AngiesGirl's avatar
AngiesGirl
Internet not working
The power is on, 2.5 and 5ghz are lit but the internet light is not working. Tried reset, restarting, unplugging.....nothing seems to work.
  • plemans's avatar
    Aug 19, 2019
    Have you check to see if the internet is working at the modem? Try hardwiring into it to see if its a modem problem or a router problem.
