rguy1
Apr 07, 2016Aspirant
Internet speed and Router settings -
You ever feel like the cable companies should be playing carnicval music - The cable company was giving me extreme speed and I was only getting 20 mps when I should of been getting 30 or better - Th...
- Apr 10, 2016
That is good idea. Starting from fresh to make sure. When you reset the router, push and hold the button until light
blinks and starts flashing, then release the button.
rguy1
Apr 10, 2016Aspirant
OIC - Thanks - Guess I'm stymied here - Thanks for the support ! Now after I get a new computer do I need to reset and clear all the old data out by pressing a pin in the router before using it in my next configuration ?
VE6CGX
Apr 10, 2016Master
