ChrisMK's avatar
ChrisMK
Invalid Device Name error when adding an Addresss Reservation
I have two devices in my Address Reservation List which were added a long time ago. I want to add some more to the list but I get an "Invalid Device Name" error message when clicking Apply. This ha...
  • antinode's avatar
    antinode
    Mar 29, 2018
    > I'm sorry you think I'm incapable of adding three pieces of
    > information, [...]
       You over-estimate your ability to discern what I think.  And my
    ability to guess what you actually did from descriptions like "add the
    details".  Hence, my questions about what you actually did.
       Ok, but that doesn't show anything about the info which you supplied
    for an "Add" operation.  (Also, there's no good reason to hide your
    private LAN addresses.)
       With my weak psychic powers, I can't tell from here, but if you
    really are putting in valid/harmless values for the "IP Address", "MAC
    Address", and "Device Name", and the "Add" operation fails, then you'd
    seem to have either bad firmware or scrambled settings (which could
    confuse otherwise-working firmware).
       The usual procedure in such cases is to reset the router, and
    reconfigure it manually.  You can try to save some work by saving
    settings, resetting, and restoring the saved settings.  If that works,
    then you're happy.  If it fails, then you still need to try manual
    reconfiguration (after another reset), because the saved settings could
    have been corrupt.
       When all that fails, you can try older firmware versions, to see when
    things went wrong.
