Bsnmate
May 17, 2017Aspirant
"Invalid Firmware Image" WNDR4300
Hello. New to Community. I have a WNDR4300 router, firmware version V1.0.1.60. A recent scan of my network with my eset security suite pointed out a vulnerability in the network and recommended upgr...
- May 18, 2017
If you download firmware from the Netgear support pages, it comes as a zip file that you have to unpack to get the firmware file.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
There are a couple of versions of the WNDR4300. Check that you have the firmware for your version.
Bsnmate
May 18, 2017Aspirant
Hello michaelkenward and thanks for getting back with me. This morning I tried again to burn the zip file and got the same results. I didn't see any options for unzipping the file prior to burning. This attempt was done from another computer just to rule out any unknowns. Then I started doing more searches for a solution and tried the route of doing the update directly from the NETGEAR Genie application. This worked fine and I am now uptodate on my router firmware. Still don't know what I was missing the other way but the Genie method worked, so the issue has gone away. Thanks again
michaelkenward
May 19, 2017Guru - Experienced User
Glad it worked. These days I have all but given up on burning files to CD. I either use them as they come or I out them on a USB drive. Much easier to manage, and doesn't even need a CD drive.
