Jed-1337_43's avatar
Jed-1337_43
IP rejected by DNS on Netgear N600 WNDR3400v3
I have a website and use CORE FTP to upload files to the DNS.  I have used the Netgear router and CORE FTP for years with not problem at all.  Yesterday I attempted to connect to the DNS to upload files and got the error message "No connections allowed from your IP Can't establish connection --> aster.arvixe.com:21 @ Tue May 11 15:56:46 2021 (0-2)"  I called my host who said the problem wasn't on their end and that the problem was with my ISP.  My host did say that my IP address 69.2X.XXX.X was blacklisted and that the ISP would have to remove it from the blacklist.
I called my ISP and the end result was that the problem is with the router.  ISP said they do not put IPs on blacklists.  Further, when I disconnected my desktop computer from the Netgear router and plugged directly into the ISP modem, Core FTP worked just fine and there was not error message.  That would mean that whatever is going on is with the router and not the internet connection or my ISP.
If I look at the network connections on my desktop, none of the IPv4s are the 69.2X...... IP address.  I don't have a clue were that IP is getting into the picture but it is in the router without doubt.
I have rebooted the router.  From instructions I have found, the router has been reset to factory defaults.
Any suggestions would be greatly appreciated.
  • > I have a website and use CORE FTP to upload files to the DNS. [...]
       "to the DNS"?  What has DNS to do with anything?
    > [...] got the error message "No connections allowed from your IP Can't
    > (0-2)" [...]
       You "got the error message" from this "CORE FTP" program, or what?
    > [...] I called my host [...]
       The organization which hosts your web site?
    > [...] who said the problem wasn't on their end and that the problem
    > was with my ISP. [...]
       That makes no sense to me.  I wouldn't expect your ISP to block your
    access to anything, nor to generate any such message.  The people who
    operate that FTP server are the only ones I'd expect to be able to do
    any of that.
    > [...] My host did say that my IP address 69.2X.XXX.X was blacklisted
       What/whose "blacklist"?
    > [...] ISP said they do not put IPs on blacklists. [...]
       That makes sense.  Any such blacklist would be associated with the
    relevant FTP server, not with your FTP client program, not with your
    router, not with your ISP.
       My guess is that someone at your "host" might have suggested that
    your ISP could give you a new/different public IP address, and thus
    evade the (that is, the host's own) blacklist, but a more efficient path
    would be for them to remove your blacklisted public IP address from
    their blacklist.
       Some of your readers can't see what you're seeing.
       Your router has two network interfaces, LAN and WAN/Internet.  If
    your router's WAN/Internet interface is connected to your ISP (typically
    through a modem), then the router's gets its address WAN/Internet IP
    address from your ISP.  That would be your public IP address.
       Devices on your LAN get their (LAN) IP addresses from the router,
    typically "192.168.0.x".  The router's NAT feature allows your local
    devices to share the one external/public address when communicating with
    the outside world.
    > I have rebooted the router. [...]
       Not a router problem.  Not an ISP problem.
       I'd contact the (lame? misunderstood?) hosting organization, and ask
    them to remove your IP address from their blacklist, and/or to explain
    how it got onto their blacklist in the first place, and how to prevent a
    recurrence.
    • Jed-1337_43's avatar
      Jed-1337_43
      Why does Core Ftp work when the desk top is plugged directly into the ISP modem but is rejected by the DNS when the desk top is plugged directly into the Netgear router?
      You say contact the DNS and have them correct the problem.  Would you think they have someone sitting in their database monitoring if my connection is directly from the desk top computer or the connection is from the Netgear router so they can deny a connection if it is from the Netgear router?
      • antinode's avatar
        antinode
        Guru
        > ISP modem [...]
           I don't know.  This is the first I've heard about that behavior.  I
        know nothing about your (unspecified) "the ISP modem".  I've never seen
        a complete IP address for any part of your system.
        > You say contact the DNS [...]
           I never said that.  I'm still not sure what "the DNS" means to you.
        To everyone else:
              https://en.wikipedia.org/wiki/Domain_Name_System
        > [...] Would you think they have someone [...]
           No, but I'd expect them to be able to see your external/public IP
        address, which is more than _I_ can do unassisted.  I can _imagine_ that
        your ISP gives your computer and your router different IP addresses when
        they're connected to your (unspecified) "the ISP modem", which could
        explain that behavior.
           As already explained, I _would_ expect any blacklist involved here to
        be maintained by your site-hosting organization, not by your ISP (who
        agreed), and not by your router (which could not generate a message like
        that, as I imagine it, anyway).
           Still a mystery. I've never seen that actual message in context,
        either.  I'd guess that it comes from the FTP server, and gets passed
        along by your FTP client program, but these are guesses based on
        incomplete information.
           Knowing nothing, I'd guess that a message like "No connections
        allowed from your IP [address]" was related to the IP address seen by
        the system which is rejecting the connection, so I'd be looking at that
        address in the two different situations to see if it might differ.
           Blame Assignment is Job One.  You seem intent on blaming your router
        (or your ISP) for things which they can't (so far as I can see) be
        responsible.  I'm always open to actual evidence, but only one of us has
        access to any of the relevant information, and he has been pretty stingy
        with it up to now.  ("got the error message", "my IP address
        69.2X.XXX.X", for example.)
           _If_ your ISP gives your computer and your router different IP
        addresses, then you might be able to induce it to give your _router_ a
        different (WAN/Internet, external/public) IP address by changing its MAC
        address (on that interface).
           Visit http://netgear.com/support , put in your model number, and look
        for Documentation.  Get the User Manual (at least).  Read.  Look for
        [BASIC > Internet >] "Router MAC Address".
           But, if your site-hosting organization had some reason for
        blacklisting your old IP address, then I wouldn't bet on a new one being
        more than a temporary work-around.
