spreewell
Feb 03, 2018Follower
Iphone connect
I just installed new router and working fine on computer but I can't connect with my Iphone 6 I put in the password and it states it is wrong. I did reset my password. I have turned my phone on and...
- Feb 06, 2018
Hi spreewell,
1. Are your other wireless devices able to connect using the same password/credentials?
2. You can verify if you are using the correct password by accessing the router UI and checking the wireless settings. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/24096
Dexter
Community Team
DexterJB
Feb 06, 2018NETGEAR Moderator
Hi spreewell,
Dexter
Community Team
