spreewell's avatar
spreewell
Follower
Feb 03, 2018
Iphone connect
I just installed new router and working fine on computer but I  can't connect with my Iphone 6 I put in the password and it states it is wrong.  I did reset my password. I have turned my phone on and...
  • DexterJB's avatar
    Feb 06, 2018
    Hi spreewell,
    1. Are your other wireless devices able to connect using the same password/credentials?
    2. You can verify if you are using the correct password by accessing the router UI and checking the wireless settings. The link below may help out.
     http://kb.netgear.com/app/answers/detail/a_id/24096
    Dexter
    Community Team
