GMAK
Jan 21, 2016Aspirant
iPhone router saturation
Environment: WNDR4000 - V1.0.2.4_9.1.86 iPhone 6S - ???? I need some brief validation please. My wife's iPhone is saturating my router. I have looked for similar issues, but can find no...
- Jan 25, 2016
After not being able to find anything important in research of iphone backup
settings, I did find this which describes my problem exactly
http://hardforum.com/showthread.php?t=1737872
My QoS recent change was not quite as fulfilling tonight as the last in the
last few nights. I thought the QoS tweak had corrected the bandwidth
problem. But, tonight's backup reared the saturation again. However it
didn't seem quite as bad, and for a shorter duration.
So I think the network saturation has been retarded, bu is still present,
although to a lessor degree.
Retired_Member
Jan 22, 2016You never mentioned your UP load speed. What is it?
GMAK
Jan 22, 2016Aspirant
1.
- Download Speed
5.13 Mbps (641.6 KB/sec transfer rate) - Upload Speed
0.69 Mbps (86.6 KB/sec transfer rate) - Latency
43 ms - Jitter
1 ms
2.
- Download Speed
5.14 Mbps (642.1 KB/sec transfer rate) - Upload Speed
0.69 Mbps (86 KB/sec transfer rate) - Latency
43 ms - Jitter
1 ms
3.
- Download Speed
5.13 Mbps (641 KB/sec transfer rate) - Upload Speed
42 ms - Jitter
1 ms
4.
- Download Speed
5.12 Mbps (640 KB/sec transfer rate) - Upload Speed
0.69 Mbps (86.8 KB/sec transfer rate) - Latency
43 ms - Jitter
1 ms
This circuit is DSL, and the quickest offered for the DSL type. I know
the DL speed is forecast as 6Mbps. But, I'm unsure of UL speed.
This is ATT. I don't know what "jitter" is, but 43ms latency seems
quite excessive to me. Although anemic, at least it's consistent.
The reason for my concern is that the older phone produced no "hog-
ging" at all. Then, the new phone rolled into town, and everything
clogged up during these synchronization process(es). But, my change
seems to have throttled the phone's network dominance. And, I've not
had any complaints regarding other phone functions. So, it appears
that all is well for the moment. I just wanted to verify that my change
was the customary adjustment for my problem.
Thanks.
