mattetjus's avatar
mattetjus
IPTV not working properly behind N600 Router (WNDR3400v2)
  Hi,   I have an N600 WiFi router (WNDR3400v2), behind which my newly accuired IPTV wont work properly;   Trying the following works: DSL-Modem -> IPTV-Box -> TV works fluently   The followi...
  • TheEther's avatar
    Jan 31, 2016
    Yes, IPTV generally uses IP Multicast.  Unfortunately, it seems that Netgear isn't very good about supporting it, though they have been making progress.  About the only thing you can try is to enable IGMP Proxy under ADVANCED > Setup > WAN Setup.
    If you are adventurous, you can install DD-WRT, which is 3rd party firmware.  DD-WRT has pretty good support for IP Multicast.
