iggy1connman's avatar
iggy1connman
IPv6 on XBox one
Hello, I am not experienced in the tech  world so please be patient.
 Is the AC1600 R6260 capable of IPv6? I think this is my issue of not connecting to Ubisoft.
It has been fine for a couple years I've had it. Spectrum internet, HUD is ok and I can play Wildlands online with someone who has the package. TIA
  • plemans's avatar
    What makes you think your issue is ipv6?
    What actual issue are you having?
    Have you tried a different DNS provider?
    Are you using any security?
    Is this on ps5? PC? What are you having issues on?
    • iggy1connman's avatar
      iggy1connman
      Actually the issue is the daily missions could be recognized and but now they can't . There was a weekly countdown on wildlands and every day it says zero days, 18 hours 20 min left. It says I am online connected to Ubisoft servers and features are available. Then it says could not synchronize online contact. Oruro-01000
      • FURRYe38's avatar
        Something to contact MS support about.
  • FURRYe38's avatar
    IPv6 isn't required to play games online.
    I've placed wildlands and borderlands online and I don't have IPv6 from my ISP as they don't support it.
    Look at the user manual for IPv6 features, if you don't see anything possible this router may have not supported it. The R6000 series is old by todays standards.
