dickstout's avatar
dickstout
IPv6 unable to find
I just purchased this device on the suggestion of my ISP. When I downloaded the reference guide i wanted to enable the IPv6. It does not exist in this version of firmware.  When will an update be made available.  i have noticed several postings from 2015 with the same problem.  Is this going to be fixed?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi dickstout,
    I have sent you a message. Please check your inbox.
    Dexter
    Community Team
    • fanasty's avatar
      fanasty
      Would you please also send me a copy of this ipv6-ready firmware for R6220?
      BTW, I am really concerned what time will there be a official ipv6-enabled firmware version, not just a beta one?
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi fanasty,
        Dexter
        Community Team
    • SethWeber's avatar
      SethWeber
      I have the same model router and the same issue. Cannot find ipv6. I would really like to be able to utilize it. Was told that this router was ipv6 enabled, that's why I bought it. Can you please help? Thank you.
  • The firmware is clearly beta code. running into a couple issues lately.
