Dazbob
Jan 12, 2021Aspirant
Is a AC1900 Dual Band WiFi Mesh Extender compatible with a D-Link AC1900 Smart Mesh WiFi Router
eX6410. Ac1900 Wi-Fi mesh extender essentials edition
Jan 12, 2021Guru - Experienced User
what actual dlink model is it?
the extender should work with most routers until you get to the full mesh routers like orbi, tplinks M-series mesh, arris mesh, etc.
They might still work as extenders but not as part of the mesh.
- DazbobJan 12, 2021AspirantThe model is a DIR-1960
- plemansJan 12, 2021Guru - Experienced User
theoretically it should work. But I couldn't find a thing when I checked the specific router for adding extenders.
You might be better off checking with d-link to see if there any issues with aftermarket extenders
