redbaron1234
Dec 07, 2016Aspirant
Is it Charter or is it Netgear?
Have Charter Spectrum and Netgear WNDR3400 router. Many years. Today tried accessing USPS site for tracking. Access denied. Tried accessing any USPS site. Access denied. Tried two computers and table...
- Dec 08, 2016
Elaine, thanks for your response. While I was waiting to see if someone had any thoughts about the situation and venting to myself a bit, I went into my router's admin page last night again to see if I could spot anything. I guess I was looking to see if I saw anything showing USPS domain was blocked. It wasn't. I noticed, though, under Block Sites that under Trusted IP addresses it was showing my LAN address. Changed it to my static Charter IP address (which is not default as Charter uses dynamic IP addresses), did not check off Allow trusted IP address to visit blocked sites, clicked apply, and tried to open USPS sites. It worked.
Frankly, I don't get it, but can now access USPS websites. Strangest thing, since only a single domain (of which I'm aware), but if I start experiencing other Access Denied messages from other domains, will dig into it some more.
redbaron1234
Dec 08, 2016Aspirant
Terri,
Since Charter has dynamic IP addresses, just decided to look up my IP address online. Just type IP address in a Google search and it will show you what that address is. Then, whatever that address is, show it in the area I indicated under the Netgear admin Blocked Sites (make a record of the address you are replacing so you can put it back to the original if it doesn't work). I don't know whether checking or not checking makes a difference. It worked for me when I didn't check it, so didn't want to mess up a good thing by putting in a checkmark. Maybe try it both ways if one or the other doesn't work for you.
Interestingly enough, the address that is identified as my public address is also what Charter shows as my static address, although my default is for Charter to use dynamic IP addresses. Dunno. For the life of me I can't figure out how a site/domain that I have used for more moons that I can count suddenly tells me Access Denied. I mean, the USPS. Beyond me how or why I should be denied access to that or who is responsible, Charter or Netgear or some nefarious evildoer playing with some of us. Dunno.
My case may be just pure dumb luck in finding a solution that worked for me.
Terrilp
After re-reading this post, i compared the dns with and without my router attached. I noticed two different dns numbers. I shut everything down for more than a few minutes, crossed my fingers... and now my numbers are the same:) I think this "may" have solved my issue. I've wasted too many days trying to solve this issue, i sure hope this is the answer!
Terri
