Shalabi04's avatar
Shalabi04
Follower
Nov 04, 2018
is it possible to set a time limit for the guest network?
hello everybody, i purchased the Netgear AC1750 router and i setup the 2.4ghz guest network for my kids. and i did the same when with my TP-Link AC1200 router. but i can't find the page with my new netgear router that allows me to set a time limit on the guest network alone, i can limit for the 2.4ghz network in general. so for example if i wanted to setup a time limit for it to cutoff at 8PM, it would cutoff the guest network and the regular 2.4 network
so i want to know if was a way to configure the guest network alone
  • Hi Shalabi04,
    Welcome to the community!
    You can install the Genie app and use it to set the time limit for the Guest Network.
    Dexter
    Community Team
1 Reply
  • Hi Shalabi04,
    Dexter
    Community Team
