Maxwel188884
Dec 24, 2020Follower
Is my hardware hacked?
Thank you in advance for any help or insight. I was curious if this is what the inside of a c6300 is supposed to look like. I have been having a lot of issues with my network and the highlighted piece...
- Dec 24, 2020
those are for the antenna. They're supposed to look like that.
What issues are you having?
do you have a screen snip of the cable connections page and the logs?
antinode
Dec 24, 2020Guru
> [...] I have been having a lot of issues with my network [...]
Thanks for that detailed problem description.
> [...] It looks crudely cut, the metal and wire soldering look
> amateurish.
You're looking at normally invisible parts of a piece of
cheap-Chinese plastic junk, not a finely crafted walnut desk. If the
wires are attached (to the antennas, I'd guess?), inside the box, then
perhaps your concern is misplaced.
