Tazzman1180
May 02, 2019Aspirant
Is my router going bad?
I am getting an organge light from my cable provided modem to my netgear router. Is the problem with the modem or my router? Thanks.
- May 03, 2019
Turns out the modem needed to be replaced. Thanks for trying to help figure it out.
Tazzman1180
Sorry for the confusion. I am using my Netgear modem as an extension wi-fi. I have a cable plugged into the Arris leading to the Netgear and that plug is the one that is solid orange. I am not am home right now so I cannot provide the model number at this time. I can tell you that it is an older model (bought it about 7 years ago).
michaelkenward
May 03, 2019Guru - Experienced User
And that Netgear modem is? (Model number?)
How is it set up? As a wireless access point?
What is the make and model of the cable provided modem? Is it also a router?
- Tazzman1180May 03, 2019Aspirant
