ozmozis
Jan 08, 2017Follower
Is router model WNDR4300v2 rated DOCSIS3.0?
- Jan 13, 2017
Docsis3.0 is cable a modem (gate way) standard not a router standard if your router can supply the speed that you pay for and handle ipv6 if what your isp supplies you your is fine if happy with it. Check with your cable company about what standard Docsis your modem is running at and what you pay for.
TheEther
Jan 08, 2017Guru
The WNDR4300v2 is a router, not a cable modem, so the question has no answer.
