AndrewC1989
Mar 29, 2021Aspirant
Is there a way to easily disable 5ghz temporarily?
I have dual band internet at home (2.4/5) and for simplicity I have the two signals meshed in my Orbi router/network. Unfortunatley when I'm doing things like setting up smart home devices that only ...
- Apr 06, 2021
So I found a somewhat decent solution elsewhere on the Netgear forums. You turn the power on the Orbi router down from 100% to 25% for the 5Ghz radio (Advanced Tab/Advanced/Wireless Settings) and disconnect any satellites you are near. If you're far enough away from the main router this will default you to the 2.4. It's not a perfect workaround but it's much better than what I was previously doing.
AndrewC1989
Apr 06, 2021Aspirant
