Peobody
Dec 22, 2021Guide
Is there a way to make a readable copy of configuration settings?
I did a factory reset after firmware update to v1.0.4.120 due to DNS issues. I became frustrated with trying to remember configuration setting so did a restore of the backup I had made before starti...
michaelkenward
Dec 23, 2021Guru - Experienced User
Peobody wrote:
Hopefully something easier than a screenshot of each screen.
That's pretty well the best/only option unless you area codehead.
BTW, I see that v1.0.4.122 is out but the release notes don't mention the DNS issues some of us have experienced with the last two firmware so I'm hesitant to try it until I can figure out how to most easily reconfigure the router.
Netgear's release notes are a joke. While there are good reasons form not going into details of security fixes, not talking about bug squished is less than helpful.
