Jeff_R6400
Dec 05, 2020Aspirant
Is there a way to update R6400 firmware from a USB flash drive?
Presently running version V1.0.1.6_1.0.4. (ancient) I want to update the firmware but I am a newb to this router's config SW. My configuration is: Verizon FIOS G1100 is my connection to the inte...
- Dec 05, 2020
No. (Not, so far as I know, with Netgear firmware. But you don't
care.)> [...] (crossover cable).
No one cares any more. Modern hardware adapts automatically.
> I left the R6400 in the router mode (not Wireless AP and not bridge).
Are you sure? WAP mode might make more sense.
> Internet works great on devices attached to either the G1100 or R6400.
Are the IP addresses of client devices in the same subnet, no matter
to which router you connect them? (That would suggest R6400-as-WAP.)
If you connect the R6400 (WAN/Internet interface) to some other
router, it might notice that, and decide to help you out by adopting a
wireless-access-point configuration without your having asked
explicitly.Seeing some actual IP addresses would clarify that.
> With the R6400 NOT connected to the G1100, I Wi-Fi connected a PC to
> the R6400 by accessing http://www.routerlogin.com. I could access the
> R6400 config software.The simple solution for a firmware update in that case would be to
download the firmware kit onto some computer or other, connect that
computer to the loose R6400, and load the firmware manually from that
computer onto the R6400. You don't need an Internet connection to allow
a computer to talk to a loose R6400.
> 1: If I attempt to access R6400 via http://www.routerlogin.com the
> R6400 apparently forwards the request to the G1100 and I end up with the
> internet provided error screen that I'm not connnected to the R6400.What's the actual message text? That's the typical result if your
DNS work is being done by a non-Netgear router. (For example, if your
R6400 were configured as a WAP.)https://community.netgear.com/t5/x/x/m-p/2010967
> 2: If I attempt to access R6400 at 192.168.1.1, the R6400 apparently
> forwards the request and I end up with the G1100's configuration
> software login screen.That just says that your G1100 is at "192.168.1.1", it says little
about the R6400, except that it probably isn't.> I have downloaded the latest firmware file R6400-V1.0.1.62_1.0.41.chk
> from Netgear. Is there a way to install the firmware using a USB flash
> drive?
No, but...Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:https://kb.netgear.com/23960
https://kb.netgear.com/31573You might also check the G1100 to see if it shows the R6400 as a DHCP
client, or what Netgear would call an "Attached Device". That should
reveal the LAN IP address of the R6400-as-WAP (if it is actually
configured that way -- which it probably should be).
antinode
Dec 05, 2020Guru
care.)
explicitly.
> drive?
No, but...
Jeff_R6400
Dec 06, 2020Aspirant
Thank you - I have some homework to do - will respond when I get the requested info.
