Feb 03, 2016Initiate
Is there any way to stop having to re-flash firmware on R6300v1?
Every time I shut the router off, or power goes out (for whatever reason), I get the flashing green light of death. Super annoying. It's a pain having to re-flash firmware. I see many people have had ...
- Feb 03, 2016
That indicates firmware corruption. Did you get a fresh copy of the fw from the NG site? Are you uploading via wired, or wireless? Had same issue with my 6300 once. Grabbed a fresh copy of fw from NG site and uploaded via ethernet connected device to the 6300. Never had the issue again. Once you have successfully updated the router, reset to factory default and reconfigure.
netwrks
Feb 03, 2016Master
- -6300Feb 03, 2016Initiate
ahh! that worked! Thanks netwrks! I was missing the reset to factory default step I think. Just followed your instructions, and now I can power off the router and it turns back on again with no flashing green light of death! Thanks!!!!
