retiredDC18's avatar
retiredDC18
Follower
Jan 30, 2021
Is WiFi Range Extender compatible with WiFi Cable Modem Router
I am trying to connect the WiFi Range Extender Essentials Edition, EX6120, to my N600 WiFi Cable Modem Router Model C3700.
Are these two compatible?  When trying to connect on the laptop, I was getting a message that I am not connected to my WiFi's extended network.
1 Reply
  • plemans's avatar
    they should setup.
    Have you tried installing the extender using the installation assistant?
    where is it failing in the process?
    What are the led's on the extender showing?
