RWADDELL_1701
Apr 26, 2021Aspirant
ISP Reports Problem with Open Portmapper - how do debug?
ORBI Netgear RB50 + Satellite Router Firmware Version: V2.7.2.104 My ISP (Rogers Canada) emailed me today to say "There's a problem with an internet-connected device in your home that's interfer...
RWADDELL_1701
Thank you for your quick reply. Looks like I did not redact all instances of the IP they sent me, but my public IP address is different than the one in the email. I'm not very knowledgeable about this stuff but I was told if I typed "what is my ip address" into Google it would tell my my public-facing IP (and I get the same value from every device I try that on), and it's NOT what Rogers sent to me.
As to your queries:
- Router Firmware Version V2.7.2.104 (I thought I put that at the top of my post, but I can't see that now when I reply to you)
- NETGEAR ROUTER ORBI RBR50 is connected via ethernet cable to the Rogers Ignite modem. My iMac is connected by cable to the ORBI, as is the Synology NAS, but everything else is WiFi.
- Can I check on my end to see if you were able to access me?
- I do not have port forwarding set up under Advanced Setup > Port Forwarding/Port Triggering
- UPnP is ON using UDP protocol with two entries in the table:
Int. Port Ext. Port IP Address 3074 3074 ZZZ.ZZZ.ZZZ 9308 9308 ZZZ.ZZZ.ZZZ
- DMZ is not configured as I don't have port forwarding set up
- ADVANCED > ADVANCED Home : Internet Port : Internet IP Address has the same value as when I use Google, and it is NOT what was in the report from Rogers.
- When I plug in the IP from above into whois-RWS it says "Customer=Rogers Cable Inc. BASP (C02170553)"
- As for rpcinfo, I plugged in the local IP for each of my three computers in the <local IP address> bit to see if there was an RPC service running - each said no. Am I supposed to use the public IP? I tried that and it still says "
Can't contact rpcbind on ZZZ.ZZZ.ZZZ.ZZZ
rpcinfo: RPC: Unknown protocol
The only thing I saw on my Synology NAS was a 'QuickConnect' item in the Control Panel which would allow me to connect to the DiskStation from anywhere. It was enabled but I disabled it, but that would not seem to be the issue as I did that before posting my topic.
One thing I forgot to mention - I have Disney Circle 1st Generation device installed to limit access for my son, as well as a Ring doorbell & chime.
antinode
Apr 26, 2021Guru
> [...] it's NOT what Rogers sent to me.
My psychic powers have not improved since:
> With my weak psychic powers, I can't see it, but you could plug that
> address into the form at: https://whois.arin.net/ , and see if it is a
> public or private address.
With no clues other than "different", there's little I can offer.
> o ADVANCED > ADVANCED Home : Internet Port : Internet IP Address has the
> from Rogers.
If Rogers is complaining to you about some other customer's IP
address, then you should be arguing with Rogers. At which point,
further investigation of your stuff might be a waste of time and effort.
> o NETGEAR ROUTER ORBI RBR50 is connected via ethernet cable to the
> Rogers Ignite modem. [...]
About which, I know nothing. A quick Web search suggests that it's a
modem+router, although it might have a "Bridge Mode" (which you might be
using):
https://www.rogers.com/customer/support/article/learn-more-about-the-rogers-ignite-modem
https://www.rogers.com/customer/support/article/how-to-bridge-your-rogers-ignite-modem
> As for rpcinfo, [...]
I can't see your actual command, but if you did it right, then I'd
expect "rpcinfo: RPC: Timed out", rather than "rpcinfo: RPC: Unknown
protocol". I infer that you still have that spurious "-T" option in
there. Copy+paste is your friend. On/from my Mac, I get plenty
(from "localhost" or its own LAN IP address):
$ rpcinfo -p localhost
program vers proto port
100000 2 udp 111 rpcbind
100000 3 udp 111 rpcbind
100000 4 udp 111 rpcbind
100000 2 tcp 111 rpcbind
100000 3 tcp 111 rpcbind
100000 4 tcp 111 rpcbind
100024 1 udp 612 status
100024 1 tcp 1021 status
100021 0 udp 712 nlockmgr
100021 1 udp 712 nlockmgr
100021 3 udp 712 nlockmgr
100021 4 udp 712 nlockmgr
100021 0 tcp 1017 nlockmgr
100021 1 tcp 1017 nlockmgr
100021 3 tcp 1017 nlockmgr
100021 4 tcp 1017 nlockmgr
100003 2 udp 2049 nfs
100003 3 udp 2049 nfs
100003 2 tcp 2049 nfs
100003 3 tcp 2049 nfs
100005 1 udp 864 mountd
100005 3 udp 864 mountd
100005 1 tcp 1023 mountd
100005 3 tcp 1023 mountd
100011 1 udp 1018 rquotad
100011 2 udp 1018 rquotad
100011 1 tcp 999 rquotad
100011 2 tcp 999 rquotadBut, (from the router) at my external/public address:
$ rpcinfo -p <public_IP_address> Can't contact rpcbind on <public_IP_address> rpcinfo: RPC: Timed out
as expected.
> RWADDELL
"R" for "Rube"?
- RWADDELL_1701Apr 26, 2021Aspirant
- Yes, the Rogers Ignite modem is set up in Bridge mode - I just confirmed it. But when I log in to the Gateway I see that it's public IP **IS** the one Rogers sent me!?!? So, it's using a different public IP than my Orbi router?
My-iMac:~ Ross$ rpcinfo -p localhost program vers proto port 100000 2 udp 111 rpcbind 100000 3 udp 111 rpcbind 100000 4 udp 111 rpcbind 100000 2 tcp 111 rpcbind 100000 3 tcp 111 rpcbind 100000 4 tcp 111 rpcbind 100024 1 udp 934 status 100024 1 tcp 1021 status 100021 0 udp 661 nlockmgr 100021 1 udp 661 nlockmgr 100021 3 udp 661 nlockmgr 100021 4 udp 661 nlockmgr 100021 0 tcp 1017 nlockmgr 100021 1 tcp 1017 nlockmgr 100021 3 tcp 1017 nlockmgr 100021 4 tcp 1017 nlockmgr 100003 2 udp 2049 nfs 100003 3 udp 2049 nfs 100003 2 tcp 2049 nfs 100003 3 tcp 2049 nfs 100005 1 udp 885 mountd 100005 3 udp 885 mountd 100005 1 tcp 1023 mountd 100005 3 tcp 1023 mountd 100011 1 udp 984 rquotad 100011 2 udp 984 rquotad 100011 1 tcp 999 rquotad 100011 2 tcp 999 rquotadMy-iMac:~ Ross$ rpcinfo -p <public ip address from Orbi router> rpcinfo: can't contact portmapper: rpcinfo: RPC: Unable to send; errno = Broken pipe
My-iMac:~ Ross$ rpcinfo -p <public IP address from Rogers Ignite modem Gateway> program vers proto port 100000 4 tcp 111 rpcbind 100000 3 tcp 111 rpcbind 100000 2 tcp 111 rpcbind 100000 4 udp 111 rpcbind 100000 3 udp 111 rpcbind 100000 2 udp 111 rpcbind- If you are referring to Rube Goldberg, I accept the compliment with thanks.
- antinodeApr 26, 2021Guru
> o Yes, the Rogers Ignite modem is set up in Bridge mode - I just
> than my Orbi router?My (perhaps insufficient) understanding of "bridge mode" is that it
implies transparency, so I don't know how you can get different IP
addresses on opposite sides of it. However:> My-iMac:~ Ross$ rpcinfo -p <public ip address from Orbi router>
> Broken pipeIt might be easier to follow this stuff if you just stopped trying to
hide the actual addresses.> My-iMac:~ Ross$ rpcinfo -p <public IP address from Rogers Ignite modem
> Gateway>
That looks like what's in the complaint, but it's not obvious that
the RB50 has much to do with it. Especially if you can't get anything
similar out of the RB50 directly.> o UPnP is ON using UDP protocol with two entries in the table:
Did you try disabling it? I wouldn't expect much, but it'd be nice
to make sure.
> If you are referring to Rube Goldberg, [...]Nope.
https://en.wikipedia.org/wiki/Rube_Waddell
Or, watch the first part(s) of the Ken Burns "Baseball" series.
- RWADDELL_1701Apr 27, 2021Aspirant
Waddell is not a very common last name so I'm surprised I'd not heard of Rube Waddell before. Thanks for that!
I'll try disabling UPnP this morning to see if that works, but I suspect I have another frustrating call with Rogers tech support in my future.
