SkySurferAl's avatar
SkySurferAl
Follower
May 17, 2021
Issue following firmware update to 1.0.1.60
I have just (succesfully?) completed the firmware update on my D7800 to version 1.0.1.60 and now all the LED's on the router (except for the power indicator) have stopped working.
I have been into advanced setup to check the settings for the LED choices and it was set to "all working" as it should be. Changed it to "all off" and hit apply, and then back to "all working" and hit apply.... no difference whatsoever.
Any help would be greatly appreciated 👍
1 Reply
  • > [...] firmware update [...] now all the LED's on the router (except
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    Back Panel description.  Pay particular attention to the "LED Off/On
    switch".  Did you operate it?  Further reading might not hurt, either.
