Pizzaguy
Oct 23, 2020Aspirant
Issue with upgrading firmware on D6100
When upgrading firmware on this model, my 5ghz speeds get halved from 80 mbps to 40 mbps and 80 mbps is the speed i get from my isp, the moment i rolledback my firmware from newer ones to older ones ...
Pizzaguy
Just did the factory reset and re-applied my settings and the same issue is happening, almost half speeds at 5Ghz and full speeds at 2.4Ghz.
i tried re-applying almost all firmwares on the router before this and it starts happening from version 1.0.0.50 to the last one which is 1.0.0.62.
the model is D6100 and i hope netgear fixes this and i found a 1 year old post with the same issue.
I've linked the post below and i hope netgear fixes this.
https://community.netgear.com/t5/General-WiFi-Routers-Non/D6100-5GHz-extremely-slow/m-p/1829301
- PizzaguyOct 23, 2020Aspirant
Is it safe/okay to revert for older versions for better use ? i hope they get it fixed.
Also just tried going through multiple firmwares, half speeds at 5ghz and even lower speeds at 2.4 ghz at times ! the moment u upgrade ur firmware from 1.0.0.46 on the D6100 model your download speeds on 5ghz are halved and ur download speeds on 2.4ghz take hits from time to time and once u downgrade to 1.0.0.46 version or lower i get solid full speed !
Another update, found another post earlier this year
same issue, it seems to be a firmware issue, i hope it's easy to fix netgear !
