Pizzaguy
Oct 23, 2020Aspirant
Issue with upgrading firmware on D6100
When upgrading firmware on this model, my 5ghz speeds get halved from 80 mbps to 40 mbps and 80 mbps is the speed i get from my isp, the moment i rolledback my firmware from newer ones to older ones ...
Pizzaguy
Also just tried going through multiple firmwares, half speeds at 5ghz and even lower speeds at 2.4 ghz at times ! the moment u upgrade ur firmware from 1.0.0.46 on the D6100 model your download speeds on 5ghz are halved and ur download speeds on 2.4ghz take hits from time to time and once u downgrade to 1.0.0.46 version or lower i get solid full speed !
Pizzaguy
Oct 24, 2020Aspirant
Another update, found another post earlier this year
same issue, it seems to be a firmware issue, i hope it's easy to fix netgear !
- PizzaguyOct 30, 2020Aspirant
Any help or update so far from the mods ?
also it seems the router shows as AC750 here while it's actually AC1200
https://www.netgear.com/support/product/D6100.aspx
i hope netgear fixes it.
