useruser38676
Apr 06, 2021Tutor
Issues after April 1 2021
Child phones suddently can't connect to internet after comming back home from Spring Break.
Until I figure out new openDNS config, I am trying to disable parental controls on R6250.
It shows "enabled" in dashbord but all menues redirect me rathen than let me turn off the feature.
Where in menu I turn it off.
1 Reply
btw - here is the change
The Live Parental Control service based on OpenDNS will no longer be supported on Netgear devices as of December 31, 2021.Effective April 1st, 2021, Netgear will remove support for Live Parental Controls from the Netgear genie app and from updated versions of their firmware. Customers can continue to use OpenDNS for content and security filtering by directly setting up an account at https://www.opendns.com/home-internet-security.
