Webby27's avatar
Webby27
Follower
Nov 09, 2020
Issues connecting 2 Xbox’s on Orbi
After resetting my Orbi system I can get both my Xbox’s to work on open Nat for COD modern warfare. After a few days I start to get one Xbox on open and then the other will go onto moderate.
I have tried port forwarding and still I get the same issue.
Why should I have to spend a lot off money on a system that will not accept more than one Xbox.
As a major manufacturer you should be making firmware that automatically does all the work for the end user.
I was thinking about looking at a new router but I am a little fed up with having to spend more money so my son and I can play online at the same time with out issues.
Please someone from Netgear get your devs who write firmware to fix these problems.
I have read quite a bit and I am technically minded but when spending over £400 for a router system you would expect this to work right out of the box.
Please help. Thanks
No RepliesBe the first to reply
