Egomez93
Aug 25, 2022Follower
Issues connecting
I changed my wifi name and now it's telling me my password is incorrect. I know for certain that I'm typing it correctly. I'm using a Netgear router model WNR2000v5.
Aug 26, 2022Guru - Experienced User
Just to add, the WNR2000 is a base model n300 (single band, slow wifi) device with only 10/100mbps ports.
If you're paying for half decent speeds or use it for more than basic internet, an upgrade would make a nice performance difference.
But if you're on slower dsl, then it'll be fine.
