Songwood
Oct 21, 2021Aspirant
Issues with connectivity when hardwired to my router but not when hardwired to my router.
Hello, I am having issues getting my game launcher to connect to the servers so I can play my MMO *FFXIV). When I am hardwired into the modem, I run into no issues. However, the moment I hardwire...
Oct 21, 2021Guru - Experienced User
1. what modem/gateway do you have?
2. what firmware is on the router?
3. Did this just start or how long has it been doing on for?
4. Are you using ipv6? (try enabling it)
5. have you tried a different dns provider like googles at 8.8.8.8 or 8.8.4.4?
Songwood
My Modem is an Arris Surf SB6190 DOCSIS 3.0 Cable Modem
The Firmware Version is: V1.0.4.120_10.0.91
I don't know exactly how long, but its been going on for a couple months now.
I have just enabled the IPV6 though i have never used it before today (new to me).
and I don't know much about DNS.
- plemansOct 21, 2021Guru - Experienced User
You can try the ipv6 and the dns option.
If they dont' help, try downgrading the firmware a version.
you put in your signature you have the R6020 but that doesn't match up with your firmware.
- FURRYe38Oct 21, 2021Guru - Experienced User
Just FYI, the SB6190 modem has long standing known issues of it's own.
