motox22a
Mar 31, 2020Aspirant
It's been a long time for a FIRMWARE Update for the R6300v2
So as the subject line says...Last Firmware update for the R6300v2 router was spring of last year... (I own three of them).. As far as I know this is still a supported router... In the interim we ...
- Jul 05, 2020
Just loaded R6300v2-V1.0.4.38_10.0.93_BETA Firmware on all three of my
R6300v2 routers. All three upgrades went without a hitch. Nice to get
security updates. Thankyou NETGEAR.
michaelkenward
Apr 01, 2020Guru - Experienced User
Are there any particular security issues that you have seen and that need addressing?
Security Advisory | About Us | NETGEAR
motox22a
Apr 01, 2020Aspirant
Yes...I am concerned about the KR00K Wifi Vulnerability.
It's my understanding this router is still supported.
Third party options are not good for this router (WiFi is not reliable and connects at lower speeds)...
I hope that Netgear will put out a patch for the KR00K wifi vulnerability for this router.
Like I said I own three of them.
- plemansApr 01, 2020Guru - Experienced User
All I can say is good luck. I hope for your sake they do but I wouldn't hold my breath.
