stheo528
Feb 16, 2021Aspirant
Jamming Device being used to access my Netgear Nighthawk.
Some crimminals are accessing my Netgear Nighthawk network to hide themselves from my cameras. I want to stop them from this activity. My Internet provider stated to hide my Network. I have read here...
stheo528
Feb 25, 2021Aspirant
Hi,
What device can overcome an IR Emitter?
Feb 25, 2021Guru - Experienced User
an IR immitter is only going to block camera's that use an IR sensor at night.
If that's actually whats going on (you haven't shown us any videos or anything), simple disable IR mode and place a motion sensor light so when there motion, it lights up the person and the camera captures it.
- wcalifasFeb 26, 2021Prodigy
does it look like they're using a laser pointed on your camera? or how is it that they're jamming your camera?
- stheo528Mar 14, 2021Aspirant
When the device they are using is pointed at my camera it flashes. the device looked like cell phone. it is difficult to tell as they are holding it their hand. I use Sibell App on my Mobile device to access the cameras. I tried to contact the company that installed the device but he does not respond either through text or to return my call. Your solution sounds like the answer, but I don't know how to do it as the installer did not give me instructions for its use other than simple things. I figured out how to save the recordings of the activity, however, I don't know how to send them. When they access the camera it goes blank and the screen is gray.
- plemansMar 15, 2021Guru - Experienced User
If that isn't something you can implement, then check into a battery powered wireless security camera that you can place somewhere hidden that won't be blocked. There's a bunch on amazon.
When the device they are using is pointed at my camera it flashes. I use Sibell App on my Mobile device to access the cameras. I tried to contact the company that installed the device but he does not respond either through text or to return my call. Your solution sounds like the answer, but I don't know how to do it as the installer did not give me instructions for its use other than simple things. I figured out how to save the recordings of the activity, however, I don't know how to send them. When they access the camera it goes blank and the screen is gray.
