somesuga's avatar
somesuga
jnr1010v2 is not connecting to the internet but working fine when i connect cable directly
Hello,   I have a 1 year old netgear wifi router, model number JNR1010v2. It was working fine until recently. It does not connect to the internet since a week .I suspect that it is because of the f...
  • ElaineM's avatar
    May 19, 2016
    Hello somesuga
    Welcome to the community!
    After the firmware update, did you reset the router?
    If not, I suggest that you do a factory reset by using a paperclip to push the reset button on it for 10 seconds.
    Once done, reconfigure the router. Follow the steps here on how configure
