somesuga
May 18, 2016Aspirant
jnr1010v2 is not connecting to the internet but working fine when i connect cable directly
Hello, I have a 1 year old netgear wifi router, model number JNR1010v2. It was working fine until recently. It does not connect to the internet since a week .I suspect that it is because of the f...
ElaineM
May 19, 2016NETGEAR Employee Retired
Hello somesuga
Welcome to the community!
After the firmware update, did you reset the router?
If not, I suggest that you do a factory reset by using a paperclip to push the reset button on it for 10 seconds.
Once done, reconfigure the router. Follow the steps here on how configure
somesuga
May 19, 2016Aspirant
Thanks ElaineMfor your quick response
I have tried resetting the router after the firmware update. It didn't work.
This time i tried again and it was not able to connect, i have given the Router MAC id to configure the Internet and it did worked.
Thanks again..
GAnesh
