Ferrcorp
Jun 30, 2022Follower
Jwnr2000v2 lan speed is too low
Greetings, i have too low speed on wan -lan connection(0,7mb/s). Whats wrong? I was replace cord, update drivers and system at router! And nothing... help me please
What modem/gateway is the router connected to?
What speeds do you pay for?
Did it ever function at full speeds?
Did something change to cause it?
Ferrcorp wrote:
Greetings, i have too low speed on wan -lan connection(0,7mb/s). Whats wrong?That's not right, Certainly needs fixing.
How are you measuring it?
But be warned that the Jwnr2000v2 is an old router with ancient technology.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.
The wifi may also not be up to much. It might not even support 5 GHz wifi.
Nothing wrong with it being old, just don't expect too much.
