JohnnyWB
Sep 20, 2015Tutor
Keep having to refressh my connection
I have the N600 WIFI Router WNDR3400V2 and all of a sudden, the last 3 months I am having to refresh my router's connection to the Internet, after a bit of idleness. I don't understand why this is h...
- Sep 22, 2015
it's a possibility that the router is starting to degrade.
normally, this should have been corrected by loading the latest firmware and resetting the unit.
however, in your case it's different it seems that it's giving additional problems as you continue to rectify the problem.
perhaps, it's time to get a newer router and be happy :smileyhappy:
doraemon
Sep 22, 2015Prodigy
JohnnyWB
Sep 22, 2015Tutor
That is the conclusion that I am leaning to. So I will now get a replacement unit and go from there and hopefully, with the newer technology, it will cure the problem completely and give me much more flexibility.
thanks,
Johny
