darwitt
Dec 28, 2017Aspirant
Kombination NETGEAR DGN1000B und WN3000RPv3: Anwendnung der IP-Adress-Reservierung
Hallo zusammen, ich nutze in meinem Heimnetzwerk den DGN1000B als Modem und Router und den WN3000RPv3 als Verstärker. Beide Geräte haben die neueste Firmware. In der Konfiguration des DGN1000B h...
- Dec 28, 2017
> Gibt es hier eine Möglichkeit, dass auch im verstärkten Netzwerk die
> reservierten IP-Adressen berücksichtigt werden?
Vielleicht. Ich weiss nichts, aber, ...
The WN3000RPv3 User Manual (English, naturlich) has a section, "Use
the Extender With MAC Filtering or Access Control". It doesn't mention
reserved addresses, but the principles should be the same. Apparently,
you may need to make two address reservations, one for the real MAC
address (for a connection directly to the router), and one for the
"translated MAC address" (for a connection through the WN3000RPv3).
If you don't already have the WN3000RPv3 "User Manual", then visit
http://netgear.com/support , put in your model number, and look for
Documentation.
antinode
Dec 28, 2017Guru
Documentation.
darwitt
Dec 29, 2017Aspirant
Hi antinode,
thank you very much for your answer. I didn't recognize that the devices get an virtual MAC-adress through the range-extender. I added the virtual adresses to the router's reservation-list, as you told me, and it works fine.
Thanks!
