kidspice's avatar
kidspice
LAN links down
I recently powercycled and factory reset my  WNR2500 as we were having connectivity issues. I know have the wireless functioning properly. However, none of the lan line ports funtion. When I connect ...
  • ElaineM's avatar
    ElaineM
    Sep 27, 2015
    kidspice Under the router admin page, do you have an IP address under Internet port?
    The configuration of the router depends on what kind of Internet connection you have from your ISP.
    Normally, if your ISP is cable you will select "Use computer MAC Address" then you should be getting an IP address on the Internet port.
