kidspice
Sep 13, 2015Aspirant
LAN links down
I recently powercycled and factory reset my WNR2500 as we were having connectivity issues. I know have the wireless functioning properly. However, none of the lan line ports funtion. When I connect ...
- Sep 27, 2015
kidspice Under the router admin page, do you have an IP address under Internet port?
The configuration of the router depends on what kind of Internet connection you have from your ISP.
Normally, if your ISP is cable you will select "Use computer MAC Address" then you should be getting an IP address on the Internet port.
kidspice
Sep 19, 2015Aspirant
HI, thanks for the welcome! Yes, I get port lights when either creating a loop or plugging into my laptop. This inability to use the lan line was all of a sudden and all 4 went down at once right after I had done a factory reset and a powercycle . WHen i plug in, I stay on wifi and when I hover my cursor over my network below my Wifi network name it says no internet with the LAN line icon.
ElaineM
Sep 21, 2015NETGEAR Employee Retired
kidspice What's the IP address of your computer when you direct connect your laptop to the router?
The IP address should be in the same range of IP when you connect to the WiFi.
Kindly post a screenshot of the result when you do IPconfig.
Looking forward to your response.
- kidspiceSep 26, 2015Aspirant
The IPs are in the same range i think.
I should say at this point that nothing works when plugged in via the ports. I learned that there was an issue when my wired bluray stopped working and when the kids' xboxes stopped working via ethernet.
IS there something I need to reset with the MAC addresses on the router? Currently i'm uding the "use this MAC address" option under internet settings on the router.
could it be something to do with whether or not I have a dynamic IP or static?
- ElaineMSep 27, 2015NETGEAR Employee Retired
- kidspiceSep 27, 2015Aspirant
THAT'S IT! Elaine, I wish I could buy you a drink! Thank You! I switched that option, promptly lost all connections, did a power cycle and bingo bango! I am tyoing this via a wired connection again.All the other reponses I got elsewhere said" BUmmer, you probably need a new router". I'm going to fool myself into thinking I played a part in this solution as I did reference which setting I was using for the MAC address.
I'm at lease 3/4 computer illiterate.....Thanks Again Mod Elaine, you're the bees knees!
