Pangear
Aug 10, 2020Aspirant
LAN PORT ISOLATION
Does anyone know whether there is an effective packet isolation between Ethernet LAN ports on this router when a device with NIC connected to any of four LAN ports broadcasts with a destination MAC a...
- Aug 12, 2020
Everything was correct in my message.
I found that any SOHO type routers including Netgear's do not provide isolation between their LAN ports by a simple test pinging from PC connected to a LAN port through the router gateway to another LAN port where is connected my device.
Probably, I would get the needed isolation by cascading two routers together and doing the same test.
Why is needed to have an isolation ? I created a home network using 3 Netgear's PLCs and 2 TP-Link's devices. Everything regarding the two-way communications worked out when I connected one TP-Link's PLC to my router's LAN1 port and one Netgear's PLC to LAN2 port
accordingly.
However, I noticed an issue with TP-Links's Utility when it broadcasts a message "Who is there ?" Netgear's PLCs respond but
TP-Link's do not have a chance - "no device connected". Using (activating ) Netgear's Genie, it discovers all five powerline devices.
So, the culprit is the backdoor path from LAN port through router to other LAN port. In my opinion, it is equired an upgrade/
improvement with TP-Link PLC Utility instead of finding more complex a hardware layout solution. We exchanged a number of emails
with an engineer in Shenzen, China where TP-Link, LTD. is located.
antinode
Aug 10, 2020Guru
> Model: R6250|Smart WiFi Router (AC1600)
Is that accurate? Firmware version?
> Does anyone know [...]
Not I.
> [...] broadcasts with a destination MAC address: "FF: FF :...: FF"
What, exactly, are you doing with an/any explicit MAC address? Have
you tried/considered using a broadcast IP address?
Is there some actual problem which you are trying to solve?
- PangearAug 12, 2020Aspirant
accordingly.
