TwoTiny2
Aug 04, 2016Aspirant
Lan To Lan Connections
Would someone please help. I have a Netgear AC1900 Nighthawk Smart Wi-Fi Router as the primary router connected to a Netgear AC1200 Model R6100 Wi-Fi Router secondary router, connection is by Lan to...
- AnonymousAug 04, 2016
it should take less than 10 minutes
reset router 2 to defaults....leave it disconnected from network...use wired PC select AP Mode.....after reboot connect to router 1 lan to AP WAN.....login to main router and look at attached devices for AP IP address and or go to setup and use address reservations so AP gets same IP
TwoTiny2
Thank you, I sort of figure that was going to be the answer, but I was hoping there might be another way to do it.
Anonymous
Aug 04, 2016it should take less than 10 minutes
