Jjycby
Mar 25, 2021Tutor
Laptop can’t see RBR750
One of my laptops doesn’t see the Wi-Fi provided by my Orbi router. Several other devices do see it and are operating fine. I may have disallowed the laptop to connect at one point by toggling it off ...
Mar 26, 2021Guru - Experienced User
What wifi card is in the laptop?
What driver version is on the wifi card?
- JjycbyApr 06, 2021Tutor
Card is Intel Dual Band Wireless AC 7260
Diver ver is 18.33.11.2
Thanks - sorry for slow response!
- plemansApr 06, 2021Guru - Experienced User
try updating the intel driver. They had issues with the 19 and lower versions.
https://downloadcenter.intel.com/product/75439/Intel-Dual-Band-Wireless-AC-7260
- JjycbyApr 08, 2021Tutor
Hi Plemans:
I updated to 21.10.1 and the laptop still doesnt see the Orbi. When I first got the Orbi a few months ago, I recall seeing a device connected that I didn't recognize and I somehow clicked on it and disallowed it to connect - this was using the Orbi app. Now I think the device I didn't recognize was actually my laptop and I've now managed to stop it from connecting. Does this make any sense to you? If my hunch is correct, how do I go back and reverse that setting? I don't see any sign of it currently on the app. Thanks.
