fyodorkaramazov
Nov 01, 2016Aspirant
Large house—want to use two R6400 routers with single SSID
Hi, I own two R6400 routers. Currently, secondary router is connected to primary via Ethernet cable, and I have two SSIDs broadcast from opposite ends of my large home. I'd prefer to use 1 SS...
- Retired_MemberNov 01, 2016
read page 128
http://www.downloads.netgear.com/files/GDC/R6400/R6400_UM_07Aug2015.pdf
use different channels 1,6, 11
use same SSID
use same PassPhrase
login to first router ...attached devices ...locate 2nd routers assigned IP....use address reservations to change IP if you want to
Retired_Member
Nov 01, 2016read page 128
use same SSID
use same PassPhrase
fyodorkaramazov
Somewhere within the rabit hole of trying to find an answer to this problem, I thought I came across the fact that switching my secondary router to an AP would require me to turn off the primary router's WiFi capability; however, your instructions proved otherwise. Thank you!
