Fhaye
Jun 23, 2017Aspirant
latest firmware 1.1.2.14 for my wnr2000v3 is BUGGY when in French language !!!
Hi, I just updated my router wnr2000v3 to the latest firmware. Bad idea ! It starts changing language interface to french, and then... I cannot access to advanced menu: the tab "avancé" does not re...
- Jun 29, 2017
OK, I found the solution by myself.
Forget the tftp stuff...
You just need to type in the browser the following URL, when connected via wired connection: http://192.168.1.1/adv_index.htm
That's it!
But remains the issue of the tab adv. which is not clickable, which drove me to this question on this board...
You might now close this discussion...
Thx anyway.
Fhaye
Jun 27, 2017Aspirant
Hi,
of course I did that... But ufortunately, the router boots up and same thing happens : no way to get the "advanced" ("avancé" in French) button,
This is due to this version of the firmware.
You might reproduce same behaviour by using a Windows PC running Windows 10 in French language.
It looks like the interface language, when in French especially, cannot allow this "advanced" button to be "clickable"...
Thanks for advice.
BR,
F
ElaineM
Jun 27, 2017NETGEAR Employee Retired
If you downgrade to the previous version will you experience the same problem?
- FhayeJun 29, 2017Aspirant
Hi,
would you please let me know how to downgrade, if I do not have access to adv. tab?
Thx & rgds
- ElaineMJun 29, 2017NETGEAR Employee Retired
Use the TFTP method. You may follow the instructions from the link below.
Reinstall the firmware on a router without the setup CD recovery tool
tftp method as explained does not work.
I cannot see a 69 UDP/TCP port on this box...
The open TCP ports are 23 (telnet), 53 (DNS), 80 (http), 3333 and 5555
Any clue ?
Rgds
