Fhaye
Jun 23, 2017Aspirant
latest firmware 1.1.2.14 for my wnr2000v3 is BUGGY when in French language !!!
Hi, I just updated my router wnr2000v3 to the latest firmware. Bad idea ! It starts changing language interface to french, and then... I cannot access to advanced menu: the tab "avancé" does not re...
- Jun 29, 2017
OK, I found the solution by myself.
Forget the tftp stuff...
You just need to type in the browser the following URL, when connected via wired connection: http://192.168.1.1/adv_index.htm
That's it!
But remains the issue of the tab adv. which is not clickable, which drove me to this question on this board...
You might now close this discussion...
Thx anyway.
ElaineM
Jun 29, 2017NETGEAR Employee Retired
Use the TFTP method. You may follow the instructions from the link below.
Reinstall the firmware on a router without the setup CD recovery tool
Fhaye
Jun 29, 2017Aspirant
That's it!
Thx anyway.
